inserting paper space layout in revit file
khaled.haras
khaled.haras
Is it possible insert paper space in revit file since the information which i need is in the paper space only not model space, since model space is filled with un necessary information and only paper space contain the information needed?
Copy the paper space information to model space of another file and link that file in Revit.
khaled.haras
how can i copy content , thanks
Ahmed_Muharram
right click on the paper space and chosse export layout to model
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
khaled.haras
Thanks for all persons sharing their thoughts about this post, and i want sharing the best solution i found for this case which the command BTRIM first determine the borders in the model space as paper space and start the command to elimenate everything outside this border and save the file in other name and inserting in revit with notice that blocks not recognized by revit.
thanks
