Importing ROBOT to Revit versions
Do you need to be on the same year versions to import from ROBOT? i.e can you import ROBOT 2019 version into Revit 2018 version?
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
It is recommended to use the same product versions but it MAY also work.
Rafal Gaweda
shefypattambi
In case if that is not worked you can try this option. export from robot like this.
Thanks for the reply and I mote the other reply/ option. Is there any Autodesk guidance or best practice noting about keeping on the same Versions?
