Is it possible to export analysis result (shear, moment, ...) from Etabs to Revit using CSiXRevit plugin or other plugins ?
I analyzed model in Etabs then Exported to Revit, But Analysis Results didn't transfer.
A quick Google Search picked up that there is an addin for ETABs for linking Revit models and Analysis this is usually the best way to transfer information between Third Party Analysis Applications ands Revit.
I would encourage you to download from the ETABS website directly as this will be the most recent.
etabs | Plugin, Add-on, Extension for Revit | Autodesk App Store
I checked your link.
"CSI Link" sends file Revit to Etabs.
"Visicon" and "Speckle" can send physical elements and not the analysis results.
But thanks for your effort my friend.
Maybe it will help you
https://www.youtube.com/watch?v=Zy2QVHYhB-U
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
14 Day Free Trial
Arman Margaryan
Hi there,i am wondering iif you tried the three tools and have a preferred one
