I cannot snap to the imported CAD Files in Revit
Hussein_Ebeid
Message 1 of 14
Hussein_Ebeid
Hello Everyone,
I cannot snap to the imported CAD Files in Revit while using orders like align or extend
Could you help with this please ?
Replies (13)
Message 2 of 14
hmunsell
select the down arrow under the Modify button in the ribbon. make sure the Select Links option is selected.
secondary question.... is your CAD File "Imported" or "Linked"?
Howard Munsell
Message 3 of 14
Hussein_Ebeid
Thank you for your reply
Actually i already done this, i can select the link but the problem appear once i select alight or extend order, one i snap to line i can not use it as a reference to align or extend to it, i hope that i could explain the problem in right way
Message 4 of 14
hmunsell
I don't believe "Extend" will not work with a link, it wants another Revit element to extend to.
Align should work though. what are you trying to align to the DWG Link?
Howard Munsell
Message 5 of 14
I can extend Revit elements (detail or model) to a linework of a DWG link without any problem.
Message 6 of 14
hmunsell
interesting... I couldn't get the extend to work.
I went back to my file to try again and noticed some lines would select and others would not. They are all "Lines"  (vs Polylines) even Lines on the same layers were not consistent. gonna have to look at my CAD file I'm using to see why.
@ToanDN... just for the fun of it.... try this file.
Howard Munsell
Message 7 of 14
Hussein_Ebeid
Yes, Exactly This is my problem, i tried again and i found that the lines which i can not use are in block references in autocad
Message 8 of 14
hmunsell
None of the blocks in my test file work either. That doesn't entirely surprise me :-).  What does is that less than half of the actual lines in the DWG Link seem to work.
Howard Munsell
Message 9 of 14
Hussein_Ebeid
so we need to explode the whole file so all line can work
Message 10 of 14
Get rid of those short lines so that the string of lines does not loop and you can extend to them in revit.
Message 11 of 14
I would not  because blocks are not the issue, closed loop lines are.  If you can't use Extend then jus use grip stretch and snap to the DWG.
Message 12 of 14
hmunsell
Personally I try never to explode a CAD Link. it brings in too much garbage into my model that I then have to clean out. but you gotta do what you gotta do sometimes.
Howard Munsell
Message 13 of 14
hmunsell
@Hussein_Ebeid just saw @ToanDN's reply.... There is your solution....
Thanks @ToanDN... i learned something today, I'm gonna go home now LOL 😂
Howard Munsell
Message 14 of 14
Hussein_Ebeid
Thank you all!
