Hi @drenahmeti93
So to do that i would advise the following
1. Delete the bolts you have currently
2. Add new bolts but choose the angle first then the HSS
3. When it asks you for a face choose the face of the angle
4. This will put the head of the bolt on the angle side
5. You can then leave the "Finish calculation at gap" ticked and they will only go through 1 face of the HSS
As for more information on the steel connections I have done a few webinars on the subject, see links below
https://info.graitec.co.uk/uk-gw-str-lp-20aug18-detailing-steelwork-in-revit
https://info.graitec.co.uk/uk-gw-aec-lp-3april20-modelling-and-detailing-steelwork
https://info.graitec.co.uk/uk-gw-str-lp-22sept20-revit-steel-modelling
These are all taken from our content portal which can be found here - https://www.graitec.co.uk/cad-courses/training-tutorials-and-webinars/advance-steel-content-portal
Rob Merriman, AEC Technical Lead, Graitec
