- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
Does anyone know if you're able to tag Revit members by a beam reference instead of their full member size?
For example if i want to tag a 305x164x40 UB by it's reference: 'B10' instead, is there any way to do this?
Obviously you can just use a bit of text with the reference but this means you'll have to update that if that member size were to change, so what i'm after is the beam reference tag that will update if you edit the member size just like a normal tag would.
Cheers,
