How to show volume in properties tab when an item is made with model in place?
when an element is modeled with "model in place option" the volume information is not appearing in the properties tab, even though the element has been assigned as a  wall / floor. while taking the material takeoff as a schedule the volume information is available.  Is there any option to make the Volume information visible under "Dimensions"  in  properties tab.
PavelAnd
Hi @Anonymous . You can not add this to the prorerty tab.
1. Change type to Generic Model. After that you will see volume in properties.
2. Create new text parameter and try Dynamo script below. It will write volume to your parameter.
Best regards, Pavel Plotitsyn.
