How to show all the structure elements on a plan?
Hi, there
Could anyone of you let me know if there is a way to show all the structure elements on a plan regardless of its depth?
As you see the picture below, the pile I drew under  slab and wall doesn't show the line and color fully.
I have tried to change the visibility and view range setting but I couldn't.....
I will really appreciate if someone can help solving this problem ^^
Accepted solutions (3)
BIM.Consultant
Set view discipline to "structural", and show hidden lines to "by discipline".
N.Oomen
Hi joo,
Earlier post will show all elements as hidden lines.
You could also try to make your walls and slabs transparent in this particular view with your view settings. I think it will also show your color then.
i would really like to hear if this helps you.
Good luck,
Niels Oomen
Best regards,
Niels Oomen
Cadac Group BV
Sr Consultant AEC
Thank you for your help! It works now^^
