Hello
I am trying to make an rebar set, that should start from bottom of the arch. And I want to give it a specified length. Due to the reason that it is not vertical, I must constraint both ends to the bottom and then change the length. Unfortunately it will always change the bottom end of the rebar, which I want to be fixed.
How can I change / select, which end of the rebar is fixed, when I change the length from properties window.
