how to rebar in diagonal way?
nadifa.aulia98
nadifa.aulia98
Hello, I'm new user of revit structure. I have this sketch of rebar
I want my rebar(s) sketch follow this diagonal line... is it possible?
I hope someone can help me, thank you!
shefypattambi
Hi @nadifa.aulia98
Could you please upload this portion of the Revit file to have a look at it?
Jamhmer_Oc
Hi @nadifa.aulia98
Create a section that is perpendicular to the element, you can guide yourself with lines and then align. In this section insert the reinforcement.
You can also align the reinforcement with the element.
Jamhmer Oc
EdwinG
if you want to place rebar parallel to left side see screencast. --> Varying Rebar Set
https://autode.sk/3xuiUEm
