How to modify automatic preferences when drawing OWSJ so that it's end point snaps to the angled beam automatically?
liojgu
Message 1 of 16
liojgu
I am drawing open web steel joist on revit 2023, which start at the roof level, from a beam at -106.6 at the start and the end point .the joist then goes to a beam whose staring point is -101.6 and whose endpoint is -380.6. How do you modify the automatic preferences so that my joist snaps to the angled beam automatically?
Thanks so much
Replies (15)
Message 2 of 16
mphungDCHNW
Try using "beam system" and create a reference plane of the same angle of the beam.
Message 3 of 16
liojgu
I'm trying to do what my online course is calling for, the teachers version does it automatically...
Message 4 of 16
mphungDCHNW
Can you elaborate little more did the option work for you ?
Message 5 of 16
liojgu
The teacher has one beam whose starting point and whose endpoint are at -101.6. The other beam starts at -101.6 and ends at 380.6. So the second beam is at an angle to allow the slope for a roof drain. The OWSJ are supported by those two beams. When the teacher drew the OWSJ she was on the roof plan, she just assigned the distance, the starting point and then the end point of the OWSJ and the joist automatically lowered itself on one side to come rest on the uneven beam.
My revit doesn't do that and I think it<s something in the options because when I hover over the end point of my joist, the snap option shows Vertival and extention. I think it should be Vertical and nearest...
Can you help me?
Message 6 of 16
mphungDCHNW
Have you tried using the Y justificationc.JPG etc ? This may help if you want to bring down your object or even a simple offset value
Message 7 of 16
liojgu
I elaborated below, I'm having trouble with the beam system because I have no idea what I'm doing 😄 hahaha
Message 8 of 16
liojgu
Let me try 🙂
Message 9 of 16
mphungDCHNW
If you have drawn a angled object and want it to rest on the angle or line of the angle just change the z/y and you will find it can either rest on top of your line or below it or even in the center
Message 10 of 16
liojgu
How do I change the Z and Y?
Message 11 of 16
mphungDCHNW
send some screenshot on what you want done etc
Message 12 of 16
liojgu
I just want The joist to rest on the beam, the teacher said not to worry about the settings because Revit snaps to the angled beam automatically, except mine doesn't...
Message 13 of 16
mphungDCHNW
let me try something
Message 14 of 16
mphungDCHNW
First create a reference plane of the angle of the roof you have. Then create a beam system and select that plane you create of the angle. if you want you can first create eq dimension on where you want the joists to be.
Message 15 of 16
liojgu
When selecting the structural component in order to draw it (in my case the joists) I just have to enable 3D snap on the options bar which appears below the Ribbon.
It now snaps to nearest...
Message 16 of 16
mphungDCHNW
So you snapped from one end to the other end along the angled beams ?
