Easiest way if from the Inset Tab > Load from Family
Load Autodesk Family
With Revit 2021.1 and later versions, you no longer need to download all the family content locally. Instead, you can use the Load Autodesk Family command to load default library families from the cloud on demand.
If you preferred to keep a local copy of the content, you can still download the library.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Where-to-find-Revi...
Jay Colcombe
Autodesk Certified Instructor
