How to Download Rebar Shapes in Revit 2025
geteway2digitalindia
Message 1 of 8
Can I download all the shapes of Rebar that are available
Replies (7)
Message 2 of 8
jay_colcombe
Easiest way if from the Inset Tab > Load from Family
Load Autodesk Family
With Revit 2021.1 and later versions, you no longer need to download all the family content locally. Instead, you can use the Load Autodesk Family command to load default library families from the cloud on demand.
If you preferred to keep a local copy of the content, you can still download the library.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Where-to-find-Revi...
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 8
handjonathan
Hi @geteway2digitalindia
Thanks a lot for posting your question to the forums!   Has the solution suggested by @jay_colcombe helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Message 4 of 8
No, not yet
However still trying
Once again I need to have the full download so that in rebar schedule I can include the shapes as image
Message 5 of 8
soudageraamer
Observer
Observer
Thanks a 1,000kgs i.e a ton for this!!!!! ❤️
Message 6 of 8
Ahmed_Muharram
Hi
you can download rebar shapes with images from here https://www.dropbox.com/s/o8e1668vdwcybmp/20161215%20-%20Rebar%20Shapes%20in%20Revit%20-%20Shape%20F...
This is according to BS8666:2005
if you are using Revit 2024 or 2025 Bending detail is now generated within Revit no need for images
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
Message 7 of 8
akashgoudappolla2025
Community Visitor
Community Visitor
thank you so much
Message 8 of 8
zenebe1232020
Observer
Observer
Rebar shape
