How to display only structural parts of floor
Joe_Hughes
Joe_Hughes
Hi, I have a floor which has a 200mm structural layer, then a 75mm substrate.
Is there any way to disable the substrate in some views?
I've tried creating a filter, but it doesn't seem to work. When I say "does not equal" nothing changes, but for example when I say "equals" it hides the structural and substrate layer.
jay_colcombe
Obviously the simplest way would be to have 2 floors stacked on top of each other.
The method of a Filter in this case is to change the appearance to an overall of the floor and hiding a layers if not really allowable as you still have the overall thickness of the floor.
You could convert your floor into Parts and this will allow a Filter to hide selected parts or an assembly.
Jay Colcombe
Autodesk Certified Instructor
Create parts from floors and filter parts using material criteria.
