how to create view along curved line or grid
virgilio_benedictos
virgilio_benedictos
hello all,
i have a curved shape bridge and i dont know on how can i make a section or a view along with the center allignment of the bridge for me to able to view the true lenght of my bridge for my detailed profile.
please help me.
Sincerely
VER
RDAOU
Hello @virgilio_benedictos
Can you post a plan view to see the curve?
virgilio_benedictos
dear RDA
all i want is to have elevation view showing the wall in development lenght..  or a section of the wall along Grid X.
i hope you have the way to make this...
thank you
regards,
VER
RDAOU
If I understood right; you need a section along the X grid (ie: curved showing true length/peremiter of the curve unrolled in a flat view). This is unfortunately not possible. Revit produces its elevations and sections based on Orthographic Projections (ie: perpendicular projections on a plane.)
When producing production drawings for curved surfaces (for resons such as application or further development of artistic/special paterns, graphics...etc) manufacturers use different software into which they can improt the revit model or recreate that element. In Revit there is a somewhat workaround for this which but to do it you need to know the principle before hand when modeling your elevations the first place. ie: it works on simple like internal walls small elements...If you model the elevation wrong the first place this method is basicly useless and not applicable
Hope the above helps.. if it does please Accept as Solution to help others too
