Civil3d alignment into Revit Structures using integration with autocad civil3d
Message 1 of 1
Whilst bring a Civil3d alignment into Revit Structures, using the integration with AutoCAD civil3d within the Autodesk REVIT extension of REVIT structures, I have received the following error when I select cross sections within the Roads and Terrain definition:
 - Unhandled exception.
Assembly name: DBridgeRoad: Overflow error.; StackTrace: at System.Drawing.Graphics.CheckErrorStatus(Int32 status)
at ...
and also when I select okay the following error appears.
Assembly name: DBridgeRoad: Curve length is too small for Revit's tolerance (as identified by Application.ShortCurveToleranc ...
I was wondering if anyone has encountered these errors before and has a solution for them.
Replies (0)
