How to create a Ribbed Slab
roquealfonso
roquealfonso
I need to model elements that are embedded inside the floor/slab, but these elements must cut or create a void in the slab/floor. I can't use the shaft option, because I need to also make a count of these elements. I have attached pictures of the floor plan and section.
L.Maas
Pleas do not double post in multiple forums. Other thread HERE in Revit Architecture forum
Louis
Please mention Revit version, especially when uploading Revit files.
awes
One suggestion. Make a void family based on a generic model face based family template. Add parameters to describe dimensions of the void family. Add parameter for volume =h x b x t. Remember to check family parameter "cut with void when inserted". Use a view with view direction up to insert void family.
Ahmed_M_Heteba
i model it using this steps :
1. i use beam system for ribs modeling
2. i use floor for compression slab
3. i use floor for slab edge (Solid parts)
4. i use model in place or generic family to model the blocks
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
