Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
How to change steel connection with foundation?
6 REPLIES 6
olivia19920423
369 Views, 6 Replies
Hi all,
6 REPLIES 6
Hi @olivia19920423
You have a generic connection on, in your project you need to load in the Base plate connection, then you will be able to change it from the generic to base plate connection.
Once you have it loaded into the project you can then select it from the dropdown
Rob Merriman, AEC Technical Lead, Graitec
vick1z
in reply to: olivia19920423
To note change detail level fine to view the connection
lim.wendy
Hi @olivia19920423 ,
Thanks for reaching out to the forum. Have you had a chance to look over the suggestions provided by our experts?
Do you have any questions about it, let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Hi!
I already loaded all the type of connection but still can not use it.
Try to select the base plate connection type during creation, before selecting the input elements (the column and the foundation)
catalin.lang
Hi all,
I'm using RFA is from Revit Libraries - Traditional Chinese - 結構構架-輕型鋼.
Is this RFA can not use connection founction?
