you want something like this?
go to modify and use align. thanks
I mean the steel connection. It is wthout steel connection.
Hi @Anonymous
There is no connection that will connect all 3 at the same time, i would use the clip angle connection for the 2 horixontal beams
Then use a seperate connection for the column to beam connection, a single sided end plate would give you what you want.
Rob Merriman, Technical Specialist / Principal Structural Designer, OLG
Do you mean this connection?
I used the "Moment and plate" connection type
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
note he has to connect 3 beams, not two:
