How join 3 H-beams
How join 3 H-beams
How join 3 H-beams
Hi
I need little help
how to join this h-beam.
Thank you.
ennujozlagam
you want something like this?
go to modify and use align. thanks
I mean the steel connection. It is wthout steel connection.
robertwmerriman1
Hi @Anonymous
There is no connection that will connect all 3 at the same time, i would use the clip angle connection for the 2 horixontal beams
Then use a seperate connection for the column to beam connection, a single sided end plate would give you what you want.
Rob Merriman, Technical Specialist / Principal Structural Designer, OLG
ArmanMargaryan
Do you mean this connection?
I used the "Moment and plate" connection type
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
Karol_Piroska
note he has to connect 3 beams, not two:
yes i think there are 4 beams
