How do I find what Revit Template I selected
Today I will start a new project by selecting the template "residential default."   A week later how can I check, in the revit program, to see what default template I have selected?  I want to be sure that I selected "residential default" and not "Structural Template," or some other template.
Luiscko
I am pretty sure that this template is not for default, in the Us Metric only are that one in the picture.
If you create a new template with this name. maybe you can see where you  saved or open you only need to click in the Button R or File and you will se your last file open in your Revit.
Luis Rodríguez
BIM Manager | Digital Transformation Lead
alt="EESignature" width="244" height="22">
Your Name
Encontraste util este post, compartelo y dale like para que llegue a mas personas como tú.
Si tu respuesta fue solucionada, te agradecemos que des click en el boton SOLUTION.
múinteoir
There is no way to tell apart from checking what families are loaded and working it out from there. See similar thread on this issue
https://forums.autodesk.com/t5/revit-mep-forum/how-to-know-which-template-has-been-used-for-the-proj...
Múinteoir
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
