How do i add Number/text in the callout tag?
Capture 3.PNGHow do i add the text/number in red?
Place the called out view on a sheet and the view number and sheet number will automatically populate in the callout tag.  You then can renumber the view if need be.
A_MAQ
this is another approach
you need to edit the call out head, go to families in project browser then to annotation ,after that right click on call out tag ,edit
inside the family you can create text shared parameter , where you can fill it manually in project
Autodesk Expert Elite
