How do i add cut line symbol in plan and section views?
Capture 1.PNGi want to create  detail view for the staircase but i dont want the beams to go to the end of the callout ,how do i add a cut line mark.
L.Maas
You can use a break line family for that. You can create one yourself or load one from the Autodesk library.
In the US metric library there is one under \Detail Items\Div 01-General.
Basically it is a detail item (view dependent) with a masking region
Louis
Please mention Revit version, especially when uploading Revit files.
When trying to load the break line symbol I got an error message. Under the Annotate tab, I selected 'Symbol' and then browsed to Detail Items\Div 01-General. Attached is the error message I received. I have a floor plan that is very large and want to show it cut on the sheet. I tried cropping my view and that works but not ideal visually on the sheet. Do I have to un-crop my view and then add the break line symbol? You mentioned it having masking abilities, thats why I am asking. Also, will I be able to create other views with other parts of the same plan without the break line symbol and masking? Thanks in advance.break line error message.PNG
I figured it out. To load Family: Go to 'Insert' tab and then click 'Load Family'. To use the break line: Go to 'Annotate' tab and then click the 'Component' drop down, choose the 'Detail Component' option.
Harywijaya.2
Your answer very helpful and worked.
I have try in section view and very awesome.
But if i using in floor plan or another view, there are warning like in below.
In Visibility setting have check for all annotation visibility.
please help me to solve this problem
thank you so much every one
mannan_9999
The break line symbol comes under the Detail items category. Please go to visibility setting, select the model category and you have to check the detail items box then click ok, so that you can see the break-line symbol in the view.
designerjulpiper
oooo, thank you for the detail cut line info, I found one in the same area for imperial, yay!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
