How can i resolve the under-shade issue for my under and over views?
sachin_jadhavVEWNL
sachin_jadhavVEWNL
Hello All,
Please review the image and suggest me solution.
Here is the requirements:-
I need to show both under and over wall in single view.
jay_colcombe
in a View by view scenario you would have to do a lot of VG (Visibility Graphics) and set some overall Override rules and then select individual Items (right click > Override Graphics in View) to change single items which are not rules by the View (VG)
Alternatively you could Create and Set Filters to override the Graphics and use Parameter controls to change the display such as Level References for Over and Under or something more simple like a referencing the Comments Parameter which can manually be edited to the references in the Legend
Finally, as you are relating to phases of construction you could utile the Phases Tool and Set Phases with Graphics Overrides for each of the Legend references as shown in your image but may be overkill.
Jay Colcombe
Autodesk Certified Instructor
sachin_jadhavVEWNL
Hi Jay,
Thanks for the solution. I have tried this multiple times, and the problem generally occurs with the slab, When I apply hatch pattern to slab It hides the under wall shaded hatch.
Can we do something about it?
jay_colcombe
The simplest method would be to just put a Filled Region for the Slab as i know there are issues in 2024 with Transparency at present.
Alternatively you could edit the Object Style for the Walls Hidden Style from Dash to Solid - Manage Tab > Object Styles
Jay Colcombe
sachin_jadhavVEWNL
That also I have tried but same thing happens And I could not change the linetypes.
jay_colcombe
Linetypes wont make a difference, its Object Styles, I can do this here without an issue
Out of interest can you not just override the Projection Lines of the elements that Appear Hidden using right Click > Override in View?
Jay Colcombe
