I am looking for a steel anchor bolt family that is flexible with the hook on the bottom.
Revit has come out with straight anchor bolts and in the steel tab under fabrication elements there are hooked anchor bolts that can be placed on fabricated plates but I am looking for a hooked anchor bolt family that does not need to be inserted thru the steel tab or attached to a fabricated plate.
