Highlighted elements are joined but do not intersect.
ksekhavati
Message 1 of 9
ksekhavati
Hello All. I am trying to join a wall with a support ledge. what I did was create the wall, picked the face of wall as my work plane and used model in place to create the ledge which goes from one to the other side of wall. when I finish, I pick the join command to join the wall and ledge together but I get the message: Highlighted elements are joined but do not intersect. any help would be appreciated.Revit Quiry_11.JPG
Replies (8)
Message 2 of 9
Ahmed_M_Heteba
make sure they are the same material and got to section view with thin lines and align them again..
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
Message 3 of 9
ksekhavati
Hi Ahmed. Thanks for replying. they of the same material. i have attached a section though the wall which looks right,as you can see the wall and the ledge are attached, but the 3D view doesn't show them as joined.
Message 4 of 9
Ahmed_M_Heteba
check that the view detail option is set to fine
Message 5 of 9
ksekhavati
detail level is set to fine in the 3D view. still no joy
Message 6 of 9
Ahmed_M_Heteba
please attach the file to check more
Message 7 of 9
ksekhavati
Hi Ahmed. I sent the file to your email account, because I don't know apart from photos here how do you actually attach a file.
Message 8 of 9
Ahmed_M_Heteba
Message 9 of 9
ksekhavati
Thanks a lot Ahmed (Shokran). that has sorted out my problem. my mistake was when I was changing the ledge property to be the same as wall, I wasn't doing this through edit in place operation. I was just picking the ledge and changed it's property through edit type under properties box.
