Hide lines in sheets between families
SaifNassar
Observer Observer
SaifNassar
Observer
Observer
Attached is a sheet of bridge layout, as it can be seen in the sheet, there are lines that sperate each different family. We are trying to remove these lines. the only way we were able to hide them is by hiding each lines separately (and there are multiple line at cross sections at different height. so it is very time consuming.
Note: Using sofistik to model the bridge segments.
mphungDCHNW
You can select one line "right click" select all instances in view andhide them.
Use Linework tool.
