Hidden Line Errors
Hidden Line Errors
Hidden Line Errors
Hi there,
Looking at my model's ground floor plan, the hidden lines appear backwards. Objects that are at the top of the plan appear with hidden lines when passing through object below them, which have solid lines. And all of the objects that should have hidden lines have only solid lines.
I may have changed the settings in the view range and cause something to go wrong. But I don't know how to fix this.
Any suggestions would be great!
Revit_Whisperer
If you think you may have changed the view settings there are a couple of things you can do to see if these resolve the issue.
Duplicate the view (with detailing if you have added annotation already)
Apply the appropriate view template to the view.
Alternate
Create a new structural plan view for that level, you will likely have to deselect "Do not duplicate existing views" to see the level you need to create a plan for.
If changes were made to the view template it may be necessary to start a project based off of the Structural template and transfer in an unmodified template.
