Help! The elevations and plans aren't opening in the structural model.
mtahajawed_
mtahajawed_
The Structural model doesn't show the plan views at structural levels 12'9'' and 23'6'', but the elements on these levels are visible in the default 3D mode.  Moreover the model is  not showing south, east, and west elevations. Upon double clicking on the blank window, the section view opens. The structural model was created in the collaborative environment using architectural model. Kindly open the central model file attached with this thread.
apjones
It looks like you need to adjust the view properties of your elevations.  See attached.
https://autode.sk/2SII3FC
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
