HELP DESIGN OPTIONS OR SOMETHING BETTER?
Goodjp1
Goodjp1
Hello Everyone, I was wondering if someone can give me some guidance or options of what I am trying to accomplish. I have been using design options to get what I need done, but the problem is the steel connections does not work in design options. What I have is multiple platforms at and I want to be able to turn some off and on in the 3d view and on plan views. Is there a way to accomplish this?
Thanks in advance
Gooder
alan_eu
What do you want to say with doesn´t work? Could you send us some print, please?
Maybe you should just duplicate the view; turn ON and OFF the connections you wanna verify and when choose the best option for you, just delete the rest and go on increasing your structural details.
Also, you could just try to do a copy (like we usually do in AutoCAD) and do the previous step. 🙂
Sometimes we need to step back 😞
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou 🙂
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! 🙂
hmunsell
sounds like a good option for WorkSets. create a workset for each platform you want to control. activate a workset and draw only what you want associated with on that workset (kind of like layers in AutoCAD). activate the next workset and do the same. the worksets can then be turned on/off per view as needed.
https://help.autodesk.com/view/RVT/2019/ENU/?guid=GUID-6054CEF3-C4E6-4334-BA43-568DF5DF5702
https://help.autodesk.com/view/RVT/2019/ENU/?guid=GUID-D5ED15A6-C652-4E7F-8C1F-F6966376A490
Howard Munsell
Goodjp1
I am not using a central file, can worksets still be used?
Goodjp1
I guess what im trying to accomplish is that i have framing at different levels and i want to be able to turn off and on  levels at different times.
hmunsell
making worksets would make the model into a workshare enabled model or "Central" model. that shouldn't stop you from using them though if it resolved the issue. is there a reason you wouldn't want it to be a central model?
Howard Munsell
