Having the name of the structural components in Rebar Schedule
geteway2digitalindia
While deriving the Rebar Schedule dia wise I need to have the principal components like Footings F1, F2...F3 in the Rebar schedule.
How to achieve this....
Replies (8)
awes
Use partition F1, F2 etc
Tom_Kunsman
There is a field in the rebar schedule called "Host Mark" - you can use this. Each footing then would need to have a Mark value.
jay_colcombe
Can you not simply use Host Mark or Category?
Also utilise Partitions for more Grouping
Jay Colcombe
Autodesk Certified Instructor
Dear Jay
Can you pls share some guiding videos on Host Mark / Partition
Merry Christmas
Tom_Kunsman
I posted something on using the Host Mark, please take a look. Also, the Rebar Partition is an Instance property of the rebars. You can select a grouping of bars and give it a Partition code/number. This parameter can then be scheduled, along with the Host Mark if you choose
jay_colcombe
This is simple schedule  creation methods by adding in extra parameters from the list
When creating or editing the Rebar Schedule simply add in the Host Mark Fields.
This is a good guide
https://medium.com/autodesk-university/ten-tips-for-effective-rebar-detailing-in-revit-392551fb4384#...
Jay Colcombe
"PARTITION" is working, however in a project where there are multiple similar structures like 2 nos F1, 2 nos F2...how do I gets "Count" field in the Rebar Schedule as 2 instead of 1.
Attached file shows that the schedule is showing all 5 rebar instances for 1st F1 followed by the same 5 rebar instances of the 2nd F1, by making the "Count" as 1.
How in schedule I can have the multiplied Count as 1 single item with the multiplication factor
jay_colcombe
The EXACT solution is in the link!
Jay Colcombe
