Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Is there a per view setting of halftone in Revit? I want a heavier tone for a particular plan and very light on another. is this possible?
Hi @francfiles
You can do it using view templates, which you create according to your requirements.
If you use filters, it is also possible.
Jamhmer Oc
Tone settings will still be the same. is there a way to have different tone settings per view? like 70% halftoning for one view and 40% halftoning on another?
unfortunately there is only one Halftone setting (under Manage > Additional Settings > Halftone/underlay). depending on what you are halftoning, you can set somthing to existing phase and adjust your Phase settings to show Existing as Halftone (which it should be by default). Then in the VT also add the halftone checkbox as @Jamhmer_Oc shows. this will "double halftone" the item. Typically you don't want to do that, but in this case.....
Howard Munsell
