Grid Circle
Grid Circle
AJA14
Grid Circle
AJA14
Hi. I can't modify the grid bubble. I have created a new bubble head with a larger radius and applied it to the grid level head but nothing changes. Any ideas why this is happening? The grids change with scale but I want the bubble to be large enough so that the text will not interfere with the bubble when exporting to Autocad.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Joe.Charpentier
The Grid bubble is a family that you can then apply to the Grid type.
Did you edit the existing family, or create a new one?
If you created a new family, you will need to do one of two things:
-Edit the existing Grid type so  that it uses the new Bubble. (Select a Grid, in the properties palette select "Edit Type".  Then change the "Symbol" to your new Grid Bubble.  Of course, you need to load the bubble into your project first.)
-Create a new Grid type using the bubble and change all existing ones to the new type.
    Select a Grid, in the properties palette select "Edit Type".  In the Edit Type Dialog, select "Duplicate".  Apply the new Grid Bubble to the Grid type.
  Now select one of the original Grids, Right click>Select all in project.  Then using the type selector, change them to the new types.
Joe
