Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Gray Families
3 REPLIES 3
282 Views, 3 Replies
Gray Families
When I load families into a project they go in but they are gray instead of black, and they wont get selected if i try to window select i have to manually click on them. And when i put some views onto a sheet and print they are barley visible, this is an issue because when i scan the sheet or try to make copies it is invisible.
3 REPLIES 3
Alan.johnson1970
Are you using full Revit or Revit LT?
AJ.
What are the Families?
Can you post  a copy of your model?
AJ.
Alan.johnson1970
What type of families are you loading in?
What discipline is your Project?
Architectural?
Structural?
MEP?
AJ.
