Graitec powerpack in revit, some issues with customize drawings.
florin-daniel.buzoi
florin-daniel.buzoi
Hello everyone,
I'm new to graitec powerpack, can you tell me why it doesn't let me select in Annotation/bending? only in the "slab" section I can't do that.
I asked Chat GPT and he told me it's because of the reinforcement families or tags, but I'm not sure if this is the problem because in the others (columns/framing/footing) I can select what I need in Annotation and Bending detail.
If you need any other information, please let me know.
with Regards,
Florin.
jay_colcombe
I do not have this addin but a quick check on the online help makes no reference to Slabs only Beams, Columns and Walls so I would initially assume it is not possible in this instance?
Generate Drawings
There was a message on importing/loading tags unless this is related someway?
There is a contact support function in the addin Help
Jay Colcombe
Autodesk Certified Instructor
florin-daniel.buzoi
then why do I also have the "slab" option. It seems very strange to me, I read somewhere that it is possible because of the "floor family" its not structural, but I checked the box to be considered as a structural element.
jay_colcombe
Have you tried inserting a Structural Slab and seeing if these option then become active?
Jay Colcombe
florin-daniel.buzoi
yes, nothing..
