Grading in Revit
franks.zinho
Grading in Revit
franks.zinho
Community I hope you can help me.
I need to do a grading in Revit, at a certain depth but I want the cut to have a certain degree of slope.
As well as the slope.
Is it possible?
Jamhmer_Oc
Hi @franks.zinho
Yes, it is possible, but not recommended. For this type of work there is Civil 3D, as it will give you earthwork reports, plans, etc.
Check here. https://forums.autodesk.com/t5/revit-structure-forum/45-degree-slope-in-the-topography-section/m-p/1...
Good luck.
Jamhmer Oc
franks.zinho
Understood. Thanks
