Footings minimum width and depth
johnpen
johnpen
Hi All, hope all is well, I am modeling my footings and would like to know is there any rule of thumb or simple formula to determine footing minimum width and depth. Thank you in advance.
Accepted solutions (3)
_Vijay
It up to which standers you following. if you any doubts or clarification in Revit  while modelling you ask here.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
hmunsell
i would have thought that is something you would have learned in engineering school :-).
Are you looking for how do do analysis to determine you placed the correct footings? checkout some of these videos on structural analysis.
https://www.autodesk.com/autodesk-university/au-online?query=footing+analysis
Or are you looking for engineering formulas on how to design the correct footing.
https://www.engineersedge.com/excel_calculators/structural_rectangular_spread_footing_analysis_calcu...
Howard Munsell
ennujozlagam
you can refer to this LINK and see if helps. thanks
M.elmekawy
First, it is something you learn in the Engineering School
Second, it is determined in the design drawings according to the code you are using
If my answer helped you please mark as a solution, this helps others to find answers quickly........
________________________________________
Mahmoud Elmekawy
Structural Engineer / Instructor / ACP (Revit Structure & Architecture)
