Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Footing under wall
4 REPLIES 4
TD&H-RLT
460 Views, 4 Replies
Footing under wall
TD&H-RLT
Hello-
I am trying to draw a cripple wall (in a crawl space) and the add the footing to the wall. I have done this before & can see all of my other ones I have drawn - but when I try to make a new one I keep getting an error. It says "None of the created elements are visible in structural plan: level 1 view. You many want to check the active view, it's parameters, and visibility settings, as well as any plan regions and their settings." I don't think I'm doing anything different than when I made these walls with the footings before.
I'd appreciate any help I can get.
Thank you
Footing under wall
Hello-
Thank you
4 REPLIES 4
Joe.Charpentier
in reply to: TD&H-RLT
Joe.Charpentier
If you go to a 3d view, can you place the footings?
I suspect that either footing are turned off in your view, or that the bottom of the wall is below your view depth.
Joe
Joe
TD&H-RLT
TD&H-RLT
Hi-
I tried it in the 3D view - it acts like it might have done something (didn't give me any warnings) but I have no idea where it is because I can't see anything.
Hi-
Joe.Charpentier
Joe.Charpentier
A few ideas:
Are you in a "Structural" view, or an analytical only view?
Do you have "foundations" turned off in the Visiblity/Graphics settings for the view?
Joe
A few ideas:
Joe
TD&H-RLT
TD&H-RLT
As far as I know I'm in a structural 3D view & no - the foundations are not off - I can see all of the other ones.
Ruth
Ruth
