Flexible conductor or cable
gideon.botesB4GMB
gideon.botesB4GMB
Good day,
We are doing substation modelling in Revit and my team is a little new on the platform.
I'm ending up with a lot of dead-ends trying to model flexible conductor in Revit.
(real-world example attached)
My approaches so far have been to try to create an adaptive component (cylinder with 4 adaptive points) and using flex pipe system families.
The problem with the adaptive component is that we have a rough time trying to get it to snap properly (to the center of a 'hole' or void cylinder). The flex pipe works better but I can't add any parameters or metadata to it.
I appreciate your patience and thank you for any help offered.
Kind regards,
Gideon
Ahmed_M_Heteba
you need to post it in MEP category
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
hmunsell
What kind of parameters/metadata are you trying to add? Flex Pipe is an category option for making parameters. even though it is technically a "Pipe", you can still add other parameters to it. might not be ideal, for representation sake it should work.
Howard Munsell
