Find view(s) that a selected object is in
davidjimm
Message 1 of 13
davidjimm
Is there any way I can find out what view or views an object is in from the 3D view. We are in a large project, and I would like to be able to select an object and find the sheet it is on. I can get the sheet from the view an object is on hopefully.
Replies (12)
Message 2 of 13
aaronrumple
You can using the API or Dynamo.
The object may show up on many different views. And may be in a view but not visible because it is hidden by another object. From the views, you can get the sheets.
Message 3 of 13
davidjimm
Thanks for the reply. I was hoping to get a Dynamo script to find the view by selecting the object. I apreciate the help.
Message 4 of 13
RDAOU
@davidjimm
You can use the "Find Referring Views" option. However, 3D elements exist in all views even if you do not see them, unless such elements are
  1. Cropped out of the view
  2. Outside view Range / Far Clipping
  3. On a closed workset or hidden by other means such as of VG or Filters
  4. On a filtered out Phase or non-primary Design option
Hence, if the objects/elements you mentioned are 3D elements, then that Dynamo Graph would more or less useless unless one of the above applies
Message 5 of 13
davidjimm
Thanks for all the help. I was able to write(modify) a Dynamo/Python script that allows you to select an object and find the views and sheets that the object appears in...
Here's the dynamo script. Very useful to us!
import clr
clr.AddReference("ProtoGeometry")
from Autodesk.DesignScript.Geometry import *
# Import DocumentManager and TransactionManager
clr.AddReference("RevitServices")
import RevitServices
from RevitServices.Persistence import DocumentManager
from RevitServices.Transactions import TransactionManager
# Import RevitAPI
clr.AddReference("RevitAPI")
import Autodesk
from Autodesk.Revit.DB import *
doc = DocumentManager.Instance.CurrentDBDocument
elementz = UnwrapElement(IN[0])
viewtemplates = list()
views = list()
viewcollector = FilteredElementCollector(doc).OfClass(View)
sheetcollector = FilteredElementCollector(doc).OfClass(ViewSheet)
for view in viewcollector:
    if view.IsTemplate == True:
        viewtemplates.append(view)
    else:
        views.append(view)
viewmatches = list()
viewmatchez  = list()
for v in views:
        viewelemidz=[]
        viewelems = list()
        viewelems = FilteredElementCollector(doc,v.Id)
        for viewelem in viewelems:
            viewelemidz.append(viewelem.Id)
        for i in range(0,1):
			elem = elementz
			elemid = elem.Id
			viewmatchez = viewmatches
			if elemid in viewelemidz:
				viewmatchez.append(v)
sheetz = list()
for sheet in sheetcollector:
    sheetz.append(sheet)
elsheetmatches = list()
    elviewmatches = viewmatches
    elsheets = list()
    for viewmatch in elviewmatches:
        sheetnum = viewmatch.get_Parameter(BuiltInParameter.VIEWER_SHEET_NUMBER).AsString()
        if sheetnum != '-':
            for sheetel in sheetz:
                if sheetel.get_Parameter(BuiltInParameter.SHEET_NUMBER).AsString() == sheetnum:
                    elsheets.append(sheetel)
    elsheetmatches = elsheets
OUT = viewmatches, elsheetmatches
Message 6 of 13
RDAOU
@davidjimm
How is knowing that the element is in 36 views useful exactly?
PS: when you copy a code, have the decency to provide a link to where it was copied from
https://forum.dynamobim.com/t/find-views-and-sheets-that-show-a-specific-element/1921/5
Message 7 of 13
davidjimm
Yeah, my first post here. Thanks for the heads up about posting where I copied it from.
To answer your question, in the project I showed an example from we have well over a thousand views, and somewhere in the range of 100 sheets.
To be able to narrow this down 32 views and 4 sheets is extremely helpful!
The key is looking for what sheets this object is on for us. Finding the views is usually just a means to find the sheets.
I open those 4 sheets, and the go to the 3D view and highlight the object. Then pan through the see where it is.
If I do have to open and page through 32 views it's a lot easier than opening 1119 views to look for it.
Thanks again for trying to help 😁. And for setting me straight on posting the link I got the original code from.
Message 8 of 13
RDAOU
@davidjimm
You didn't need to type such a length reply I still do not see the usefulness of knowing the object appears in 36 views...apart from that, I wouldn't be looking for Beams Reinforcement details on a Furniture layout.
Message 9 of 13
davidjimm
I need the SHEETS that the object is on, per the original post. "We are in a large project, and I would like to be able to select an object and find the sheet it is on."
If I right click on an object and go to find referring views...
These are the views I get that refer to this object. Of those views only a few of them will actually be put on sheets. To find those sheets I would have to open up all those views.
If I run the dynamo/script, it gives me the 3 sheet names that have this object on it (SC-1214,SC-1123,C-0106)
I think it's helpful. If you don't I understand.
Message 10 of 13
robert.jungergard
Can you post the dynamo script? I tried to re-create it from your views and the copied code but I couldn't get it to work. I re-created it in 2022, and I got an error message about Dynamo is moving towards Python Engine 3 instead of 2.
Message 11 of 13
davidjimm
I'll try to update my Dynamo code and repost it. The models we're working in are Revit 2019, but I do have Revit 2021 on my computer. I'll get the program to run on that and repost it.
Message 12 of 13
davidjimm
Ok, here's the Dynamo file from Revit 2021.
Just for some clarification, I left the first "select" node blank. If you leave that node blank, when the users run it in the player it will ask for an object. If you fill it in, it will use that object and not ask.
Maybe 2022 has a different Python version than this, hopefully you can still get it to work. I'd be happy to do anything else you can think of.
I'm going to post the picture, code, and try to attach the file also. A little redundant, but maybe it will help.
import clr
# Import RevitAPI
import Autodesk
views = list()
    else:
        views.append(view)
for v in views:
        viewelemidz=[]
        viewelems = list()
			elem = elementz
			elemid = elem.Id
sheetz = list()
    elsheets = list()
        if sheetnum != '-':
Message 13 of 13
payam.rad
This is a great tool to have, especially if there is a change and you want to make sure all the sheets impacted with the changed elements are identified and clouded, etc.
Seems like it is taking much longer if you have some sheets that are not part of the set, as this goes thru all the possible sheets in the project and takes a lot of time. It would be great to include another parameter to only go thru sheets that are part of selected "sheet index" schedule for example. Would you be able to include that feature as well?
