Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Fabrics cutting plans
8 REPLIES 8
Message 1 of 9
643 Views, 8 Replies
is there a way to make fabrics cutting plans similar to this one below:
or any at all???
Regards!
8 REPLIES 8
Message 2 of 9
ovidiu_paunescu
Hello @Anonymous
@teodorb might be able to help you with this one.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
Message 3 of 9
teodorb
in reply to: ovidiu_paunescu
Hi @Anonymous,
Could you please provide more information about your needs. What are you trying to achieve? Why there are areas not filled by fabrics? Why aren't you using any overlapping for fabrics? Could you please describe the workflow?
Kind regards,
Bogdan Teodorescu
Product Owner
Message 4 of 9
in reply to: teodorb
Hi Bogdan,
what I need to provide the contractor are fabrics cutting plans. So, when I have to draw a slab (or wall) like this:
I have to provide fabrics cutting plans like this (or similar):
That way contractor knows how much fabrics (rebar sheets) needs for slab (or wall) and how much of it is unusable!!! I've seen this in third party Revit add ins but couldn't manage to accomplish this!
Is there a way to make something similar?
Regards!
PS: The above layout is made in 10 seconds and fabrics are generated automatically.
Message 5 of 9
teodorb
Hi @Anonymous,
There are no ways that I know of of doing what you are searching for in pure Revit.
Kind regards,
Bogdan Teodorescu
Product Owner
Message 6 of 9
peticid
Hi Mark,
Can you please tell me which Revit add-on you're using to create the fabrics cutting plans?
Kind regards,
Dan Peticila, M.Sc. Str. Eng.
Product Manager | Autodesk Revit
Message 7 of 9
You should look into Dynamo for doing this. i have seen several scripts that do very similar layouts for curtainwall that I am sure could be changed and developed for your situation
Message 8 of 9
in reply to: peticid
Thank you guys!
The add-on I'm using for fabrics cutting plans is for AutoCAD only (not Revit)!
But, I think SOFISTIK managed to program something like this for Revit!? Cutting plans are very common in Europe and I wonder why are not provided with Revit. Hope it will be implemented in future versions!
Regards!
Message 9 of 9
@Anonymousguru2
can you attach some links for this "problem"?
Thanks!
