Exporting to CNC
Exporting to CNC
hvcprecast
Exporting to CNC
hvcprecast
Hi
I am the precast industry.
and with precast you are not only dealing with concrete to make things happen especially when it comes to precast double wall panels or sandwich panels . For instance if i have a 10' wide by 16' High sandwich panel i also need 160 Sq of Styrofoam which will be 5 sheets of 4' by 8' sheets but will need to be cut in half so they fit and also if i have a window in there (that also needs to be cut out)
So I need to export and send this info to a CNC router to do this
And My question is can REVIT do that?????
John
jay_colcombe
You have such functionality to use the Precast Tools which allows for Export to CAM files directly from Revit, there also is an Autodesk Tutorial on this exact process;
#Precast detailing and fabrication using Revit - Perform a CAM export | Autodesk
Help has a section on this too;
Help | Export CAM Files from Precast Assemblies | Autodesk
There are also 3D Exporter Addins which can do the same - an example below
CNC Exporters | Revit add-on | ARKANCE Be.Smart Software – ARKANCE LITHUANIA (agacad.com)
Jay Colcombe
Autodesk Certified Instructor
