Hi Guys,
So I'm in the process of integrating Revit into our company with the purpose of switching the team over from AutoCAD to Revit.
Currently I'm busy creating the line types(scale, weight, patterns .etc.) as well as dimension and text styles to match what we're currently using in AutoCAD.
My issue comes in when exporting to AutoCAD.
1) I've renamed the layer of i.e a text with a leader, however it comes ou in AutoCAD as white though is should be cyan. Also the text and the leader are on the same layer which I wish show in two different colors. I can't find the different layers under Revit Exports Setup. Please help.
2) I have chaged the Loaction lines of my beams to show as a dash dot line on the same scale as our Center Lines in AutoCAD. Though when I create an elevation the location lines should once again be seen but in the middle of the beam and column. Currently what I found is the the Location line sits on top of the beam but I cant figure out how to move in to the centre. And on the columns.... I don't know where it is. I presume it would be dot right at the tom of the column. The purpose of the Location line which I hope to achieve is have them show in Plan, Section and elevation on all steel members as center lines.
Thank you in advanced!
Kind regards,
Jake
