Exporting revit views to DWG lines issue
nizarmalek10
nizarmalek10
Hello, guys,
I have an issue in Revit when I export my view I'm supposed to get the same type of lines, but unfortunately I'm getting another type of lines, for example the grid line this is getting boring every time I export I have to modify it manually does anyone know the solution for this issue? Here is an example
Cordially.
Nader_ASSAF
Are you using a customized export setup to create the DWG files?
Cordially,
NA.
nizarmalek10
No im using the default one
nizarmalek10
I have tried to change parameters and I found the solution here it is in case someone is looking for something like this
Nader_ASSAF
You can save your own setup too and transfert it to other projects.
This video could help you more :  https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-3739AD36-FBAA-41E3-AC83-6D79C3C276CD
Cordially,
NA
