Exporting Dwg and maitain shared cordinates in sheet views
patkson
patkson
Hi All,
I am having a bit of a challenge exporting(sharing) my sheet views to dwg to other consultants for collaboration purposes and since most of other consultants on the project are CAD users, maintaining the shared coordinates is very important.
I noticed when my structural plans are exported from views directly the shared coordinates works perfectly and my other consultants don't have problem xreferencing our drawings.
But unfortunately I cannot just send the drawings in views without proper title block and things like that.
So guys, is there any way around this, so that I could export my sheet views in Revit to cad and still collaborate with my guys ( what is the best practice)? Your thoughts will be much appreciated.
Many thanks,
Patrick.
apjones
Patrick, it sound like to me you are experiencing the same problem mentioned here: http://forums.autodesk.com/t5/revit-structure/dwg-sheet-to-coordinats/m-p/5801280#M13283
I suggest you review this and see if it sheds some light on your issue.
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
hanslammerts
Funny to read that this is marked as 'sollution'
I guess there are a lot of CAD people out there with the same SHARED wish for dwg xyz coordination ..
