Export Rvt Mode To Analysis Tool Robot
Mohamed-Nassar
Mohamed-Nassar
What is the Best Practice to Export The Revit model to Robot analysis?
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
ennujozlagam
you can refer to this LINK and see if helps. thanks
Mohamed-Nassar
Hello Sir @ennujozlagam
I hope you are Structure Engineer and Draft this Methodology as Pros and Cons for the best workflow from your technical point of view.
I would like to thanks you for your interest.
Best Regards,,
