I am currently working on trying to find a solution to automatize the take-off of added LCA parameters in Revit.
My problem is that I can't assign for example the GWP value to a specific material ( as an example for Concrete C30/37, the GWP value is 218.34 [kg CO2 equiv. /m³], but it is not possible to add such a property to the material itself. The five Asset tabs are not customizable. I tried to create parameters that are then linked to the families or types, but if we have a floor, as an example, with multiple layers (with multiple materials, for example, concrete C30/37 and a bitumen layer), it is impossible to link the wanted value to the floor. In fact, only the Concrete GWP value will be linked to the floor, but the bitumen has also a value that must be considered.
Is there any solution? Maybe there is an addon that exists which enables you to add an Asset tab to a material? (I have looked it up, but didn't find any)
It would really simplify the Life Cycle Assessment of buildings if this was incorporated.
