Export IFC file.
Export IFC file.
mr.engineer.aec
Export IFC file.
mr.engineer.aec
 Hi guys,
I'm trying export ifc file.
After i export ifc file from Revit, i append it into Naviswork. But file visible some lines as under pic.
Can i hide this lines when export and how to do ?
Thank in advanced.
onuresen50
Hi, you can create a section box to isolate your model without taking these lines into your section box.
There is a tutorial on how to make that.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
But why don't you just delete the lines, export, then undo the deleted lines?
These lines are not visible in your Revit?
mr.engineer.aec
Hi @onuresen50 , thank for your reply.
 It is sample file of Revit 2019
In Revit, lines are not visible and i don't know category of them.
