Export analytical model to CIS/2
cuen.saul
cuen.saul
Hello everyone,
Today I have a simple but very important doubts, how can I export my analytical model from Revit to CIS/2 to use it in a structural analysis software.
From 2009 to 2015 we had Revit Extension with this ability but for 2016 we have no Revit Extensions. I used Advance Steel Extensions but it looks like it only exports a model for steel detailing and not the analytical model for structural design.
Is there any solution or should I say goodbye to using the analytical model from Revit.
Thanks and regards.
Saul Cuen
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi Saul
To which program do you want to export model in CIS/2  format?
Many structural calculation sofware have direct links or Revit addons to import analytical models directly.
Rafal Gaweda
cuen.saul
Hi Rafal,
Especifically I need to export the model to CIS/2 to import it into Staad.Pro.
But the comment would be that, according to AISC, the format CIS/2 is an "universal" format for sharing steel buildings information, so the software being used should not make difference.
Anyway, if I can import it to Staad.Pro, that would solve my situation.
Thanks for your reply.
Regards.
Saul Cuen
Rafal.Gaweda
Autodesk Support
Autodesk Support
cuen.saul
Hi Rafal, thank you for your reply.
Yes, I saw this add like 7 years ago and I think this kind of solution will have to be the one to follow (if this tool is updated to the last version of Revit, version after version). Obviously I was after the same process of previous years using the useful Revit Tools or CIS/2 Import/Export, my complain is like why to change something useful for something not useful. Anyway, I'll give it a shot and see how a paid third-party software works.
Thanks again.
Regards.
