Error exporting rebar file from revit 2023 to navisworks
duypham.isystem
Message 1 of 17
duypham.isystem
I get an error when trying to export the nwc file and open it in naviswork. The rebar elements are thrown from their original position. I would be very grateful if someone helps to solve this problem. Thank you everyone and sorry for my bad EnglishUntitled.pngスクリーンショット 2022-06-15 140103.png
Replies (16)
Message 2 of 17
j.schuklina
We have the same problem  😞
Message 3 of 17
peticid
Hello @duypham.isystem , @j.schuklina ,
Could you please share the RVT and NWC files with us, so that we can investigate what is happening? It would also be good to know for which version of Revit and of Navisworks you experience this and if this happens sporadically or for any model containing reinforcement. If you can't share these models publicly, please reach out to me by hovering the mouse over my user name and using the "Send Private Message" option.
Kind regards,
Dan Peticila, M.Sc. Str. Eng.
Product Manager | Autodesk Revit
Message 4 of 17
peticid
I just wanted to let you know that we managed to reproduce the problem, so our teams are investigating this. We will get back once we know more.
Kind regards,
Message 5 of 17
duypham.isystem
Thank you for your interest in my problem
I will send you the data right under this section
i tried opening it in naviswork 2022 but the result is the same
only revit version 2023 is having problems
Hope to hear from you soon. Sincerely thank
Message 6 of 17
peticid
Than you too, @duypham.isystem  for sharing your files with us. These are very helpful to our development team.
Kind regards,
Message 7 of 17
-FDC-
Same problem over here !
Export form Revit 2023 to Navisworks nwc.
Very frustrating !
Export to ifc is working fine.
Opening the Revit file in Navisworks → same problem
Revit is also making windows crash.
It started with Revit 2022 on my previous Lenovo P73
Same on my new Lenovo P17 Gen2
Upgraded to 2023 → same problem
Installed 2023 on my Dell Precision 7710 → same problem
Very, very, very frustrating !
If I remember correctly the problems started after working local instead of BIM360 or the Construction Cloud (due to smaller projects).
Message 8 of 17
peticid
Hi Filip,
I am sorry to hear about these problems you are facing. While we are currently investigating the Navisworks related issue, we would also like to see what is making Windows crash. I have sent you an email, so that you could share your files with us for us to take a look.
Kind regards,
Message 9 of 17
guruh.surya
I'm also have same problem about this , I hope immediately fix soon , thank you
Message 10 of 17
peticid
Hi everyone,
I would like to let you know that the recently released Navisworks Manage 2023 Update 1 includes the fix for this issue. Besides installing this, you also need to install the updated version of the Navisworks NWC File Export Utility for Revit, available here: https://www.autodesk.com/products/navisworks/3d-viewers. (Note: the name of this extension looks the same as it was for the first release of Navisworks Manage 2023, but this is the updated tool that enables the correct export of reinforcement).
Hope this helps and please let me know if this has worked fine for you.
Kind regards,
Message 11 of 17
duypham.isystem
I tried and it worked fine. sincerely thank
Message 12 of 17
j.schuklina
It works! Thank you! 😍
Message 13 of 17
peticid
Thank you all for your validation and feedback.
Kind regards,
Message 14 of 17
duypham.isystem
sorry, I keep having problems exporting rebar files from revit 2023. This time it's about rebar being split into small chunks resulting in increased numbers in the Clash Detective report. Is it because of my settings?スクリーンショット 2022-09-13 160510.png
Message 15 of 17
guillermodiazNFTUD
Observer
Observer
Buenas, estoy teniendo exactamente el mismo problema, las armaduras me las divide por fragmentos a la hora de exportar. Espero puedan ayudarme.
Muchas Gracias
Message 16 of 17
bim_feederikn
Community Visitor
Community Visitor
can u explain what setting u have? cause my problem were naviswork wont open my rebar model sometime , and i have an issue with rebar splitting into small piece like yours, thanks
Message 17 of 17
hnin_nandar_win
Community Visitor
Community Visitor
Anyone know this problem, help me.
